Land Pride 8' 3 pt. rotary cutter
   / Land Pride 8' 3 pt. rotary cutter #1
nckennedy
Camillus, NY, USA
JD 5425
Just getting ready to replace the cutting blades on the RIGHT side of the rotary cutter and realized that the two cutter spindles move in opposite direction to each other, thus balancing the machine. So when replacing the blades on the right side, are the two bolts a standard left hand thread, or is right hand??
   / Land Pride 8' 3 pt. rotary cutter #2
You can look at a parts list to see if the blade bolts are all the same part number or some are different. I would expect the blade bolts to all be right handed as there's not really any loosening force on them that depends on the direction of rotation. The nuts are tightened down on to a shoulder on the bolt and the blade pivots on the shoulder.
Sounds responsible. Thank you very much.
Craig
   / Land Pride 8' 3 pt. rotary cutter #4
Craig
They are right hand thread both sides. Blades are one side clockwise and the other counter clockwise. Different part numbers.
2017 GENIE GS-2646 (A52472)
2017 GENIE GS-2646...
2016 MITSUBISHI OUTLANDER SPORT (A52472)
2016 MITSUBISHI...
2024 JOHN DEERE FC 10 R LOT NUMBER 84 (A53084)
2024 JOHN DEERE FC...
2019 CHEVROLET SILVERADO 1500 (A52472)
2019 CHEVROLET...
2005 PETERBILT 357 TRI AXLE DUMP TRUCK (A52576)
2005 PETERBILT 357...
(1) 14ft Tarter Gate (A51573)
(1) 14ft Tarter...
