Land Pride 72" Landscaper Rake modified for Imatch/Quick Hitch
   / Land Pride 72" Landscaper Rake modified for Imatch/Quick Hitch #1
BloomingtonMike
Platinum Member
John Deere 3320
I had a 72" Land Pride Landscaper Rake that was included with my property when I bought it. It was an older model. I finally got around to modifing it to work with my Imatch quick hitch system. Since the lower pins were very very narrow I puchased a 26" long Cat1 bar from Tractor supplu and welded it to the front of the rake. I then purchased a new top hitch from a local Land Pride dealer and drilled it to fit the existing frame making sure to offset it for the new bar. I also purcased a new stand from land pride. All that came with it was the leg of teh stand. I found some pipe of the proper internal diameter and cut off a 2 3/4" piece with the chop saw and cleaned it on the grinder. I then drilled a hole through it for the pin. Got out the welder again and welded it to the frame. Painted the entire body of the rake with some Land Pride beige paint. Then I bolted on that drilled top hitch with new grade 8 bolts and installed a top link pin. Reassembled the rake blades to the body and installed the support stand. Backed up the 3320 and it worked like a champ. Here are a couple pictures of the result.
   / Land Pride 72" Landscaper Rake modified for Imatch/Quick Hitch #2
Very nice. When I looked at the photos at first I thought it was a new rake and factory done.
The I-match is a great hitch. It is so much safer and faster than 3pt without the quick hitch. Do you ever want to grab those still sixty years in the past and tell them "GET ONE - YOUR BACK WILL THANK YOU" The I-Match should come as a free bonus for every new small JD. A smart dealer would have four implements set up for the hitch and would drive from implement to implement showing how fast it is. He probably would sell more implements too.
I had a frustrating day yesterday however because my blade no longer has a built in stand. I need to make one like yours.
   / Land Pride 72" Landscaper Rake modified for Imatch/Quick Hitch #4
It looks to me lake a factory job. Nice work!
   / Land Pride 72" Landscaper Rake modified for Imatch/Quick Hitch #5
Great job! That is a nice rake to begin with, made better by you!
2016 Ford Explorer (A56859)
2016 Ford Explorer...
2025 AGT H15R Mini-Excavator with Dozer Blade & Pilot Controls  (New/Unused) (A59225)
2025 AGT H15R...
CATERPILLAR CB24B DOUBLE DRUM ROLLER (A52707)
CATERPILLAR CB24B...
2008 GMC C7500 CREW CAB FLATBED DUMP TRUCK (A57192)
2008 GMC C7500...
2019 Ford F-550 Altec AT41S 40ft. Bucket Truck (A55973)
2019 Ford F-550...
CATERPILLAR 305 CR EXCAVATOR (A52709)
CATERPILLAR 305 CR...
