Red Horse
Veteran Member
- Joined
- Dec 12, 2010
- Messages
- 1,198
- Location
- Bolton, MA
- Tractor
- Deere 655ZTrak, Deere 4720 Cab, 400 X LT 155
Well for a couple of years now I have been maintaining some long gravel common drives utilizing a heavy 65" box blade with 7 scarifiers as well as a 72" Land Pride Power rake. The land pride does a good job of "milling" the graded base (in this neck of the woods graded base is a mix of 3/4"crushed stone-or trap rock and the resultant dust. It is about the heaviest stuff you can get.. But if I have a section that is heavily potholed, I will set the scarifiers and rip out a good section in the heavily potholed area. Unfortunately some of the people on these drives think they are in the Baja- Plus a lot of them can't be bothered to take their trash to the dump so they have a packer pounding down their road at least once a week.
In anycase, if money were no object, I would go buy a land plane as there seems to be no doubt that in a lot of situations they can do a good job of leveling and filling voids with a few passes. But then I got to thinking. for 80 bucks I can buy 4 new heavy ripper shanks. I also have a heavy cutting edge lying around so I'm thinking, what about cutting the four shanks at the proper angle, welding some drilled mounting angles to them and then bolting the cutting edge on. Thus I would have a low front edge (as on a land plane) and then the cascading material would be accumulated in the box and if the build up becomes too much, you simply empty the box.
Any opinions?
Any opinions?
