Has anyone used a Steiner or Ventrac with the three point hitch to pull a land plane or a disc harrow? I have a gravel driveway that needs leveling and would like to harrow up some land to plant a deer plot.
Not well suited for serious soil or gravel engaging work unless you use the power rake. Since the tractor is built low to the ground for stability, the hitch points on standard 3-point hitch implements like blades or disks are too high so that when lifting the implement there is little ground clearance.
Thanks Jack, is the ground clearance issue a problem for loading equipment on a trailer or is it a problem transporting equipment across a field? Also, aside from the clearance issue, is the tractor strong enough to pull it to do the job?
New Holland T2310, Kubota L3010 GST, New Holland TC21DA, Farmall H *** Previously - 1941 John Deere B, Shibaura SD1500, John Deere 850, Bobcat 642, New Holland 1925
I would think you could do 4' of either. You might also consider a pull type road drag or an older pull type (horse drawn) 4' - 6' single disc.
Here is a video of a road drag I built. You would want to make it a bit smaller
Both transport and loading could be problematic. A hydraulic cylinder top lift link would almost be mandatory. The simple land plane shown by the previous poster would work for your driveway.
Here is a guy in OHIO using a small disk on a Steiner tractor which is similar to Ventrac. You can make your own judgment about how effective it is.
Another option for the food plot would be to pick up an old section of a spring tooth (they run between 3' - 6' wide). They do better in the sod, roots, trash ...
