Laidong 45hp Engine overheat - 454 Tractor
   / Laidong 45hp Engine overheat - 454 Tractor #1
Blui
Dotau 4570
'58 DavidBrown, '48 IH-T6, '17 454-cn
Interested to know if anyone here has got one of these engines in their tractor & how it runs under load.
Got a new 2017 Eurolepard 454 45hp (foton) that I get overheat (gauge & Light) only when slashing, day temp. about 30deg.C , Maybe I am expecting too much from the Chinese engine. Tested thermostat ok (ran without for a test = same overheat)
It uses a lot more fuel than the DavidBrown (~40hp, she is old & tired). The DB temperature stays normal when slashing same. Its not heavy long grass either. Slasher is 1500mm (5') .
other Chinese diesel engine I have are very efficient.
   / Laidong 45hp Engine overheat - 454 Tractor #2
Did you clean out the radiator? Many modern tractors' radiators need cleaning often when cutting brush.
   / Laidong 45hp Engine overheat - 454 Tractor #3
But is the readings and warnings real? Can it be a sensor error?
I did a water drop test just after I got it, when I had short hose issues, (Fill rad & let go of bottom fitting, water gushes out.
The gauge seems to be accurate, operating temperature as per manual, however I will fit a test thermometer for confirm.
Fan belt is properly tensioned, no fin blockage.
cheers.
2023 John Deere 6120E MFWD Tractor (A53342)
2023 John Deere...
2004 International 4300 Box Truck, VIN # 1HTMMAAMX4H667102 (A51572)
2004 International...
2014 PJ TRAILER 40' TANDEM AXLE GOOSENECK (A52472)
2014 PJ TRAILER...
SHOULE RM8080 LOT NUMBER 129 (A53084)
SHOULE RM8080 LOT...
2023 SMITH CHALLENGER SCM 400 SWEEPER (A51246)
2023 SMITH...
MILLER SYNCROWAVE 351 TIG WELDER (A52472)
MILLER SYNCROWAVE...
