Builder,
The model numbers designate the capacity in kilograms - 510 kg = 1120 lbs
and 720 lbs = 1580 lbs. The "3" is the third generation
The LA513 is not compatible with a backhoe so if all you want is a light loader, that is the one to buy.
The LA723 has much heavier weldments and larger bore cylinders - a better choice for heavier work and if your wife OKs the backhoe, you are ready to load the trailer!
Have fun!
