Loader LA463 Loader Sticky When Lifting / Lowering
   / LA463 Loader Sticky When Lifting / Lowering #1
flakrat
Birmingham, AL
Kubota L2800 HST
Howdy, I have an LA463 on my L2800 hydrostat tractor.
The FEL control is sticking when lifting and lowering, but fine for bucket roll.
Based on what I've read, I need to remove the control valve on the lift / lower side (YW240) to clean it out / remove moister.
When I unscrew it, am I going to lose a bunch of hydraulic fluid?
Do I need to disconnect the quick disconnect hydro lines from the controller before I unscrew the valve?
Am I approaching this from the right angle?
Here's the control valve parts breakdown:
Kubota LA463(L28 / L34) (FRONT LOADER) Parts Diagrams
Thanks
   / LA463 Loader Sticky When Lifting / Lowering #2
Sounds like the spools might be worn.
Might not be a bad idea to take it off the machine and take it to your local hydraulic expert to see if it needs to be rebuilt.
You'll lose a little bit of fluid, but not like it will hurt anything.
I've attempted to locate the "spools" on controller, but can't find anything that matches with images I've seen from other FEL's. Are the spools the YW240's?
   / LA463 Loader Sticky When Lifting / Lowering #4
I did that on our B7500 this winter, there was water in the cap on the end of the valve that was freezing up and not letting it go in or out of float.
No fluid lost, just 2 Allen head bolts that I had to loosen up to take the cap off, here is what I found inside the cap:
Aaron Z
Looking at mine, they don't appear to have "caps" that can be removed. The diagram shows what appears to be a ring (snap ring?) at the end of the valve. Wonder if they have replaced this with a newer model that is easier to work on.
   / LA463 Loader Sticky When Lifting / Lowering #6
Looking at the diagram, I think you just need to loosen the big piece of sticking out of the bottom of the valve, part P or F in the diagram and the piece where the detent balls ( Part 50 or 100) are located is inside of that, be very careful not to lose them or it will not lock into detented float position anymore.
Aaron Z
   / LA463 Loader Sticky When Lifting / Lowering #7
Thanks
As a first step, assuming your loader hoses have quick connects, swap the bucket hoses for the lift arm hoses to see if the problem changes. Often issues arise when quick connects do not fully seat.
As for the actual valve spools, the clearance between the spool and its bore is too small for a normal mechanic to be able to measure. 0.0005 perhaps. Lots of zeros. That is why no seals are needed between the spool and the valve body. Problems can arise in the ends of each spool where detents and the like are located.
Dave M7040
2001 Ford F-550 (A56858)
2001 Ford F-550...
2019 Chevrolet 1500 Silverado Crew Cab Pickup Truck (A55973)
2019 Chevrolet...
(APPROX 15) 2" X 6" X 20'- 3/8" THICK METAL TUBING (A54757)
(APPROX 15) 2" X...
case 370 glass door never installed (A56435)
case 370 glass...
2021 BMW 1200RT (A55853)
2021 BMW 1200RT...
2008 International 7500 T/A Altec A77T 76ft. Bucket Truck (A55973)
2008 International...
