LA404 loader hydraulic coupler interchange with others?
   / LA404 loader hydraulic coupler interchange with others? #1
poosniffer
Swanton,Vermont
Kubota B3030HSDC
Good morning fellow Kubota owners.I have purchased a 3 point hitch log splitter that will require hydraulics.I would like to use power from one of the loader ports at the front of the tractorandrun the hoses back to the splitter.my question is,are the hydraulic couplers that you disconnect to remove the loader a standard fitting or are they a Kubota specific part that I will need topurchase from the dealer.Thanks in advance for any help with this.Best wishes.-Andy.
ps... I posted this in another section as well hoping for more exposure.Thanks.
   / LA404 loader hydraulic coupler interchange with others? #2
Three different threads all on the same topic are totally unnecessary ... it essentially becomes "clutter" on the site ... :(
Moderator please delete this thread.Thanks.
   / LA404 loader hydraulic coupler interchange with others? #5
You can delete your own thread/post within 24 hr.
At the bottom of the post you will see edit, select it and select delete.
If you don't see edit, you can't delete the post.
2002 Bobcat 763 High Flow Compact Wheel Loader Skid Steer (A55851)
2002 Bobcat 763...
2002 CATERPILALR D8R HI-TRACK CRAWLER DOZER (A52707)
2002 CATERPILALR...
2023 Kubota KX057-5 Compact Excavator with Angle Blade (A55314)
2023 Kubota...
2022 Case IH 8250 Axial-Flow Combine (A53485)
2022 Case IH 8250...
2022 KENWORTH W900 SLEEPER (A55745)
2022 KENWORTH W900...
2022 Kubota Z422-54 Zero Turn Mower (A55314)
2022 Kubota...
