la272 or la302 loader
   / la272 or la302 loader #1
texblonigan
Bronze Member
Minnesota
Kubota B7500
My neighbor asked me if there was any difference between the LA272 and LA302 loader, other than the 60 lbs lift difference. I have no idea, but said I would send it out and see if anybody knows of any major differences.
   / la272 or la302 loader #2
Differences between LA272 and LA302:
65 pounds difference in lift capacity.
115 pound difference in breakout force.
15 pounds difference in net weight.
Relief valve setting at 1900 to 2000 vs. 2100 to 2200 psi.
Same cylinders and valve.
   / la272 or la302 loader #3
I've often wondered why Kubota offers the two different loader models with such similar specs to fit one machine (B7500, the 7400 uses the LA272 only) . I'd be curious to see both and do a side by side comparison. Maybe there are differences in the mounting or the subframe that might make one a better choice than the other.
2014 INTERNATIONAL 4300 INSULATED COLD BOX TRUCK (A54607)
2014 INTERNATIONAL...
2013 John Deere 450J LT (A47477)
2013 John Deere...
2017 FREIGHTLINER CORONADO SD122 DAY CAB (A54313)
2017 FREIGHTLINER...
2024 ATLAS CORPO PACF44 PORTABLE DEWATERING PUMP (A54757)
2024 ATLAS CORPO...
Utility Trailer (A52377)
Utility Trailer...
2012 International 4300 Vacuum Excavation 7.6L Diesel Truck w/Vanair Vacuum (A51692)
2012 International...
