la211 loader valve
/ la211 loader valve #1
frenchboy
kubota bx2200
Does anyone know where i can get a parts breakdown for the loader valve on my LA211 loader. I think I need to dissassemble and take a look but don't need springs,balls,and other goodies flying around. Thanks
/ la211 loader valve #2
I bought a cd on ebay for like $7 that covered the loader, mower, and tractor. Here is the pdf for the parts manual. It doesn't give service procedures, but I know the part numbers for the pipes were right on for me.
View attachment LA211 Loader.pdf
/ la211 loader valve #3
frenchboy,
unless you DEFINETLY know your problem is in your control valve I wouldn't open it up.....you may add to you problems if it doesn't go back together properly....
shy of the spools not going all the way in/out, or having trouble with the spring return/float......or the valve creeping under load, there's little you can do for it just taking it apart....
Best to do more troubleshooting before opening up components on a fishing excursion......:confused2:
Troubleshooting can be costly, but BAD troubleshooting is VERY costly..
wdchyd said:
frenchboy,
When I pull back on lever to raise bucket I cannot pull back to the lever stop. If I do nothing happens. I have to carefully push lever forward from this point to a " sweet spot" before bucket will move and then it is weak and moves slowly. I have had this tractor for years and this is a new problem. I have checked all fittings and all other loader functions seem normal.
/ la211 loader valve #5
Have you tried to swap the lift hoses with the dump hoses to see if the symptoms swap out around.....
You could be right about the control valve, I'd just be sure....
If the spool on the control valve is binding then it would be in the rear cover (opposite side of the exposed spool)......that section will come apart without dismantling the whole valve....
/ la211 loader valve #6
also don't overlook the linkage if you have a joystick control ..
I will continue the quest. Thanks for the help
/ la211 loader valve #8
Check your spring centering springs located under one of the bottom caps. While you have it opened, clean inspect and replace anything necessary, and lube all parts.
Check springs A, and B on page 9 in the control valve.
KingKutter XB (A64126)
2017 CATERPILLAR 950GC WHEEL LOADER (A65053)
2017 CATERPILLAR...
2010 Sauber 25' Tag Trailer (A62613)
2010 Sauber 25'...
CASE INTERNATIONAL 3330 HI-CYCLE SPRAYER (A63291)
CASE INTERNATIONAL...
Bobcat Mini Grapple (A64126)
Bobcat Mini...
2018 CATERPILLAR TL1055D TELESCOPIC FORKLIFT (A65053)
2018 CATERPILLAR...
