LA211/BX2200 Hydraulic Hose Routing Help Request
   / LA211/BX2200 Hydraulic Hose Routing Help Request #1
webhund
Central Iowa
Kubota BX2200
A couple of hydraulic lines blew out on my BX2200 last week, so I thought I would just replace them all while I was at. Good plan, until I forgot to take note of how the hoses were positioned and routed coming out of the valve manifold. It's a really tight fit. Unfortunately, the LA211 parts manual doesn't show the routing through the FEL frame and it's a little unclear about some of the hose ends. I did mark which hose connected to what line/coupler, but didn't take note of the routing in between.
Could someone please describe/post an image of how the 7 hoses are routed through the FEL frame to the 3 tractor quick-connects and also to the 4 steel hydraulic lines that are under the top frame bar of the FEL?
My feeble attempts at putting this back together aren't working and I don't want to force any hoses or put them back in rubbing/chafing on each other/the FEL frame, or the tractor).I started describing how I recall the setup was before I demolished it, but it got very long and too confusing - a picture would be worth at least a thousand words here!
(BTW, my LA211 and BX2200 are circa 2002 with a 3 position valve that has 2 hoses connecting out the bottom of the manifold, 4 hoses connecting on the face/top of it in a :: type of configuration, and the 7th hose connecting kind of catty-wompus on the front off to one side. The whole thing (valve, control lever, and bracket) bolts to the FEL frame at about a 45 angle.)
   / LA211/BX2200 Hydraulic Hose Routing Help Request #2
Wow, 15 years later and I have need of this request. Does anyone have a picture or help for me. I thought I kept track of the hoses. But, things are running backwards now when I use the control. I also have the 3 way valve
Doug
   / LA211/BX2200 Hydraulic Hose Routing Help Request #3
Don't know if this will help:
   / LA211/BX2200 Hydraulic Hose Routing Help Request #4
I believe it has with one item. It showed me that the blue and red tape lines got to the bucket.
I don't seem to have yellow tape on on my other two lines. I am assuming they are the arms for the loader.
It seems from comparing you pics to my lines that things work on the valve with out and return flow. Top to lines are out and bottom two are "return". Yes/no?
But, these pics have push me further and I thank you.
Doug
   / LA211/BX2200 Hydraulic Hose Routing Help Request #5
Wish I could help more, but I can't get to that tractor right now. If you can't figure it out, I'll try to get some more pictures, loader is off right now.
   / LA211/BX2200 Hydraulic Hose Routing Help Request #7
Not as of yet. I have printed the above pictures and was starting to compare my lines to his pics.
I ran out of time to start exchanging the lines around. News to follow.
It would be nice if there was a diagram on the 3 way valve control. But, beggars can not be choosers.
Doug
   / LA211/BX2200 Hydraulic Hose Routing Help Request #8
download kubota book and you get all the diagam hope you get it mario
2020 FREIGHTLINER PT126SLP TANDEM AXLE SLEEPER TRUCK (A59575)
2020 FREIGHTLINER...
Sedan (A59231)
Sedan (A59231)
2008 TEXAS BRAGG GOOSENECK FLATBED (A58214)
2008 TEXAS BRAGG...
John Deere 6110M (A53317)
John Deere 6110M...
Unused 2025 CFG Industrial QK16R Mini Excavator (A59228)
Unused 2025 CFG...
1969 VOLKSWAGEN BUG (A59575)
1969 VOLKSWAGEN...
