LA145 having troubles starting
   / LA145 having troubles starting #1
D3nM
Midlothian, TX
John Deere LA145
Had my LA145 worked on a couple of times for it not starting. Try to start it at least weekly. But does not go easily. I have tried starter fluid and it will start, but immediately it dies. Kind of at a loss what to do. Don't want to take it back into the shop!! Any wisdom would be greatly appreciated!!
   / LA145 having troubles starting #2
The choke is out of adjustment. Either adjust cable or bend linkage to get it to full choke.
2011 John Deere TX Gator 4x4 Utility Cart (A49461)
2011 John Deere TX...
Heavy-Duty Round Bale Trailer - Tandem Axle, High-Capacity Hay Hauler (A51039)
Heavy-Duty Round...
GENERAC MAGNUM LIGTH PLANT (A50854)
GENERAC MAGNUM...
2022 Ford F-550 XL Crew Cab Forestry Chipper Truck (A49461)
2022 Ford F-550 XL...
2024 Ford F-350 Super Duty XLT FX4 - Like-New, Loaded, Only 780 Miles (A51039)
2024 Ford F-350...
RIGID 150 PSI AIR COMPRESSOR (A50854)
RIGID 150 PSI AIR...
