LA1353 Loader Arm Reinforcement or Repair?
   / LA1353 Loader Arm Reinforcement or Repair? #1
ace10
Rural NoVA
I'm looking at an M9540 (out of state). Overall it looks clean, but the (private party) seller is disclosing that the arms of the LA1353 have two small plates welded on the outside of the arms just above the pivot for the lift cylinders.
This is on an M9540 of 2009 vintage.
Seller provide pictures:
Left Arm
Right Arm
I've searched TBN like a mad man looking for any references to this being a weak point on this loader... there are no repair threads and nothing about preemptively beefing up this point.
This work was done by the PO of the tractor. So the seller claims to have no knowlegde of the situation.
Anyone care to share their thoughts on what this is all about?
Many thanks, in advance...
   / LA1353 Loader Arm Reinforcement or Repair? #2
How many hours does the tractor have on it? Does the CO know what the PO used it for? I would think there must have been some stress cracks there or worse for that to have been done. It might not be a deal breaker but I would closely inspect if you can before you buy and see if the loader is tweaked and make sure none of the holes are egg shaped. I have put my 8540 through a lot with my grapple and I've seen no ill effects.
   / LA1353 Loader Arm Reinforcement or Repair? #3
I really couldn't see your pictures, but we have used our M8540 pretty darned hard without any problems though we have only had it for a few months.
Fixed the pictures.
1200 Hrs on the clock.
Did not ask seller about PO's usage.
The machine overall looks very clean, but it should biing only one model year old.
   / LA1353 Loader Arm Reinforcement or Repair? #5
I wonder if he changed the cylinders and the plates are to accommodate that change, Do the pin diameters and cylinders appear to be stock and match Kubota specs?
   / LA1353 Loader Arm Reinforcement or Repair? #6
Fixed the pictures.
Seems like an odd situation all around. Machine is 1 year old, has 1200 hours and you would be its 3rd owner because the 2nd owner is unloading it (no pun intended :)). And the FEL has some amateur patchwork on one pivot point on each arm. I'm trying to imagine what they could have been doing with it that would bust that particular seam like that. Maybe something that involved pressing down with the FEL, like pounding fenceposts or breaking concrete? Kinda sends up a warning flag, doesn't it?
   / LA1353 Loader Arm Reinforcement or Repair? #7
With a tractor this new, you'd have to wonder why Kubota didn't replace the loader if it failed. Perhaps it was used improperly and they wouldn't stand behind it? One can only speculate unless you get the story out of the chain of owners. That's a lot of hours (IMO) for a 2009. I understand the lack of availability of large used Kubotas, but the fact that you posted for opinions on this means you aren't comfortable with the "repair" and this might be a great deal to leave for someone else.
   / LA1353 Loader Arm Reinforcement or Repair? #8
I don't know about this particular situation but can only add my humble opinion through several equipment purchases. When I purchase equipment new I treat it respectfully but not as great as many of the "TBNers" do. I do not abuse it but don't worry if it goes over a few hours before changing the oil. I never have problems with my purchased new equipment.
My used equipment always seems to have problems and I suspect you will find the same with this piece - The story does not add up. Those are some thick arms and to fracture them takes some serious torque.
You might be getting it for an awesome steal in which case I say buy it but please don't pay good old normal "private seller retail" and then pay to haul it home and then be unhappy. You can imagine what the rest of the tractor went through if those arms are spent like that!
Good luck - and you are being very smart getting other people's opinions! Someone might have a great reason that needed to be done but I can't think of one.
This reminds of one time when I was young I was dying to buy a huge backhoe and loader. Fortunately, after I looked at it (too nervous to drive it) I brought my Dad along for the second and final look. He drove it into a loose topsoil pile and the engine revved up but the wheels didn't spin. The loader just sat there. He suggested that I not buy it. I didn't want to hear that so he told me to go down and talk to our local mechanics and explain that when you pull into a loose pile the engine revs up and the wheels do not spin. I was too embarrassed to do that and passed on the "great" deal. He was smart enough to re-encourage me to ask the mechanics and I understood his advice over my enthusiasm!
If it was me I would let that puppy sit there unless it is an unbelievable steal (junk parts price).
   / LA1353 Loader Arm Reinforcement or Repair? #9
Oh - just one more humble opinion - I read this in a Donald Trump book when I was younger and I am sure many others have expressed it. "The best business decision I have ever made is one I decided to pass on".:)
   / LA1353 Loader Arm Reinforcement or Repair? #10
Does it look like the loader came with the tractor or could it be an older one that was put on a newer tractor? It's also possible that the original owner had loader break on them at the pivot in the past and decided to weld a plate before it had a chance to break not really knowing if it would ever break or not.
Just curious, I think all of the loaders that fit the grand L40 tractors end in a 4 while the older grand L30s end in a 3 (at least I think so). So why does the Mxx40 tractors have a loader that ends in a 3?
2018 Generac MLT6SM-STD3 6kW Towable Light Tower (A49461)
2018 Generac...
2013 BMW X3 AWD SUV (A48082)
2013 BMW X3 AWD...
2014 John Deere 635F Grain Platform (A50657)
2014 John Deere...
2016 Big Tex 24ft. T/A Flatbed Trailer (A50322)
2016 Big Tex 24ft...
2019 HINO 155 16FT BOX TRUCK (A50505)
2019 HINO 155 16FT...
2006 Ford F-150 Pickup Truck (A48081)
2006 Ford F-150...
