LA 211 FEL on a BX2200
   / LA 211 FEL on a BX2200 #1
ICUJOSEPH
2005 Kubota BX2200D
installing a LA211 on my BX2200D, just installed the Hyd. Block however, Im having a hell of a time trying to figure out how the Hyd. lines are supposed to be routed on the tractor, I know that they are formed specifically for the tractor, however, Im finding difficulty figuring out where they are supposed to go around, under or through? the are metal so not pliable at all and want to make sure I place the where they are suppose to go. I looked at the LA211 installation diagram and it vaguely mentions it but no clear pics or diagrams. Anyone have any pics of or a diagram of the correct routing?
   / LA 211 FEL on a BX2200 #2
The first set of 3 lines come from behind the left wheel under the op station floor to the front going under the oil pan. The shorter ones connect under oil pan and then mount on right side of the engine in the block. You will add the disconnects there. The short lines look wrong but will work, the long ones you have to hold just right to get them in place.
Parts manual attached
  • LA211.pdf
2013 International DuraStar 4400 Altec AM547 50FT Material Handling Insulated Forestry Bucket Truck (A51692)
2013 International...
2023 John Deere 6R 155 MFWD Tractor (A53342)
2023 John Deere 6R...
2014 AMADAS SPC-6-36 LOT NUMBER 211 (A53084)
2014 AMADAS...
JOHN DEERE 4066R LOT NUMBER 23 (A53084)
JOHN DEERE 4066R...
JOHN DEERE 2038R LOT NUMBER 175 (A53084)
JOHN DEERE 2038R...
3 Point 36'' Lay Off Three Rows Plow (A51573)
3 Point 36'' Lay...
