LA 211 FEL on a BX2200
   / LA 211 FEL on a BX2200 #1
ICUJOSEPH
2005 Kubota BX2200D
installing a LA211 on my BX2200D, just installed the Hyd. Block however, Im having a hell of a time trying to figure out how the Hyd. lines are supposed to be routed on the tractor, I know that they are formed specifically for the tractor, however, Im finding difficulty figuring out where they are supposed to go around, under or through? the are metal so not pliable at all and want to make sure I place the where they are suppose to go. I looked at the LA211 installation diagram and it vaguely mentions it but no clear pics or diagrams. Anyone have any pics of or a diagram of the correct routing?
   / LA 211 FEL on a BX2200 #2
The first set of 3 lines come from behind the left wheel under the op station floor to the front going under the oil pan. The shorter ones connect under oil pan and then mount on right side of the engine in the block. You will add the disconnects there. The short lines look wrong but will work, the long ones you have to hold just right to get them in place.
Parts manual attached
  • LA211.pdf
2000 John Deere 1860, 30ft Wide, Gandy Box, Wing Fold, 7.5in Spacing (A52748)
2000 John Deere...
2017 Jaguar F-Pace AWD SUV (A50324)
2017 Jaguar F-Pace...
2017 Dodge Grand Caravan SE Van (A50324)
2017 Dodge Grand...
46006 (A51694)
46006 (A51694)
