L6060 Using Oil
/ L6060 Using Oil #1
Hilbilly
Barriere, BC
Kubota Grand L6060HSTCC
I've got a 2019 L6060 with 340hrs on it and I noticed the engine oil level is going down. Since the oil change at 50 hrs the level has gone down from the top mark to about 1/3 of the way down to the lower mark on the dip stick. I don't see any sign of oil below the tractor, where it is parked, so I assume it is using the oil. Is this normal?
/ L6060 Using Oil #2
I find the oil level can change on my tractor if it's parked on a different spot from when I last checked it, and the ground level has changed slightly even. and it can also very a little depending on if the engine is cold or hot when it is checked. Always compare your oil level checks on a level parking spot with the engine warmed up every time.
/ L6060 Using Oil
Thanks but I park it in the same spot every time and that is where I checked it. Mind you it was cold but I'm pretty sure there is no way that the oil temp would make that much difference on the dip stick. I'm talking about an inch below the top mark. Just in case, I will go check the level again to see if there is a change since it now warmed up after 2 hrs of blowing and plowing snow.
/ L6060 Using Oil
I'll be darned! :shocked: I just checked it and the oil level is quite a bit higher. It's only down about 3/8" below the top mark. Don't think this is anything to be concerned about.
/ L6060 Using Oil #5
I found that the tractor parked in it's carport stall is not as level as I thought. Hydraulic oil showed 3/4 of a quart low. Drove it out on the driveway - hydraulic oil showed right at the top mark. Warm tractor- level location.
/ L6060 Using Oil #6
All sounds good then! Fluid level discrepancies on newer machines especially are always a concern.
/ L6060 Using Oil #7
Good practice to always pull the dipstick, wipe, reinsert, pull and then read the level. The tube can hold oil at the incorrect level until the the seal is broken between the dipstick and tube.
/ L6060 Using Oil #8
This may not apply in your case but the oil level will ALWAYS go down after an oil & filter change as the fresh oil fills lines and the new filter. Sometimes, I have to add as much as a quart to get the level back to the full line after running the tractor for a few minutes under load.
/ L6060 Using Oil #9
Yes, it does make a difference. Sometimes more than you think.
2014 ISUZU NPR 4X2 18FT BOX TRUCK (A59911)
2014 ISUZU NPR 4X2...
TPL MECHANICS BODY LUBE SKID (A60429)
TPL MECHANICS BODY...
2019 GMC SIERRA HD 3500 (A63569)
2019 GMC SIERRA HD...
207923 (A63290)
207923 (A63290)
2005 Ford F-150 Ext Cab Pickup Truck (A61573)
2005 Ford F-150...
2023 Unverferth 3PT 6 - FT Perfecta Field Cultivator (A63688)
2023 Unverferth...
