L5240 HST chatter
   / L5240 HST chatter #1
snoboy58
maple valley
branson 4020
Our L5240 recently developed a chattering in forward and reverse. Tractor is used for snow blowing in a mountain neighborhood. Tractor has 665 hrs. We had to relocate the tractor by driving it due to no chance of maintenance in the location where noise developed so by the time we had driven it to where we could park it for trailering it had become extremely noisy and now barely moves. It's a loud chattering while driving, if stopped no noise, it does not make noise while operating implement hydraulics ie joy stick or 3 point or steering only a drive noise. In my mind it's as if the HST pump has failed or acting like clogged filter but Fluid and filters have maybe 50 hrs on them and fluid is full. Changed filters today just to see what we could see and suction filter magnet was covered with metal and the fluid that we drained from the suction filter was full of metal. Any hip shoot ideas? I already plan on taking to dealer but was hoping to hear some thoughts. Thanks
Mike
   / L5240 HST chatter #2
   / L5240 HST chatter
Thank you moship, thats alot of information.
   / L5240 HST chatter #4
How many hours on the 5240?
   / L5240 HST chatter #5
OP stated 665 Hours in the original post.
   / L5240 HST chatter #6
Hip shot ideas: the symptoms sure point toward serious internal part failure. The problem might be in the HST, or it could be in the L-M-H range gears, or final drive gears/bearings, or even the brakes. Is it the same in 2wd/4wd?
Which of the filter(s) had metal debris inside? To run a distance making that kind of noise it sounds like something beyond the HST - in the travel gearing somewhere. No harm in hoping for the least checkbook damage. But there will definitely be some. Best luck, Dick B
   / L5240 HST chatter
Yes same in 2 or 4wd. It's definitely catastrophic failure of something expensive. Suction filter on R/H side of tractor was full of metal. It's the one with the magnet. The oil that drained out of the suction filter (aka Hydraulic filter) has so much brass in it that if it were gold I'd be rich. LOL. The Hst filter on the L/H side was clean and has no magnet to my knowledge.
   / L5240 HST chatter #10
I believe it's a 2007.
Oh. So is mine. I hope I'm not looking at the same problem. I'll hit 1000 hours this year. I guess it's time for a filter change and autopsy.
2015 DODGE RAM...
30ft Pole S/A Towable Trailer (A49346)
30ft Pole S/A...
2008 FORTITUDE MANUFACTURING 40X96 FLATBED (A50854)
2008 FORTITUDE...
(INOP) NEW HOLLAND B95 BACKHOE (A50459)
(INOP) NEW HOLLAND...
2012 INTERNATIONAL DURASTAR 4400 4X2 SERVICE TRUCK (A51406)
2012 INTERNATIONAL...
2014 UTILITY 53X102 DRY VAN TRAILER (A51222)
2014 UTILITY...
