L5240 HST chatter
/ L5240 HST chatter #1
snoboy58
maple valley
branson 4020
Our L5240 recently developed a chattering in forward and reverse. Tractor is used for snow blowing in a mountain neighborhood. Tractor has 665 hrs. We had to relocate the tractor by driving it due to no chance of maintenance in the location where noise developed so by the time we had driven it to where we could park it for trailering it had become extremely noisy and now barely moves. It's a loud chattering while driving, if stopped no noise, it does not make noise while operating implement hydraulics ie joy stick or 3 point or steering only a drive noise. In my mind it's as if the HST pump has failed or acting like clogged filter but Fluid and filters have maybe 50 hrs on them and fluid is full. Changed filters today just to see what we could see and suction filter magnet was covered with metal and the fluid that we drained from the suction filter was full of metal. Any hip shoot ideas? I already plan on taking to dealer but was hoping to hear some thoughts. Thanks
Mike
/ L5240 HST chatter #2
/ L5240 HST chatter
Thank you moship, thats alot of information.
/ L5240 HST chatter #4
How many hours on the 5240?
/ L5240 HST chatter #5
OP stated 665 Hours in the original post.
/ L5240 HST chatter #6
Hip shot ideas: the symptoms sure point toward serious internal part failure. The problem might be in the HST, or it could be in the L-M-H range gears, or final drive gears/bearings, or even the brakes. Is it the same in 2wd/4wd?
Which of the filter(s) had metal debris inside? To run a distance making that kind of noise it sounds like something beyond the HST - in the travel gearing somewhere. No harm in hoping for the least checkbook damage. But there will definitely be some. Best luck, Dick B
/ L5240 HST chatter
Yes same in 2 or 4wd. It's definitely catastrophic failure of something expensive. Suction filter on R/H side of tractor was full of metal. It's the one with the magnet. The oil that drained out of the suction filter (aka Hydraulic filter) has so much brass in it that if it were gold I'd be rich. LOL. The Hst filter on the L/H side was clean and has no magnet to my knowledge.
/ L5240 HST chatter #10
I believe it's a 2007.
Oh. So is mine. I hope I'm not looking at the same problem. I'll hit 1000 hours this year. I guess it's time for a filter change and autopsy.
/ L5240 HST chatter #11
Sorry to hear about your problems, and I'd also lean toward some major internal failure with that much metal.
On the positive side, it's good to see you keeping your sense of humor. Others would immediately jump to bashing their tractor brand and swearing off ever owning one again. I'm sure you're frustrated, but you seem to look at things the same way i do (**** happens, roll with it)... Congrats for that anyhow
/ L5240 HST chatter #12
Mike,
First please accept my sympathy that your HST is toast. They ordinarily have a very low failure rate. A high percentage of symptoms are due to linkage and not a big deal. But when one of these units truly goes tango uniform its pretty nasty.
Multiple tractor operators shouldn't be the root cause here. HST tractors are actually more tolerant of inexperienced operators than clutch/geared type. But more operators can mean rougher treatment. Maybe a simple sign-in sheet for users would encourage reasonable operation?
/ L5240 HST chatter
Yes sir rbargeron that's a big 10/4. We have created log books for the Kubota and our plow truck (which I installed a hobbs meter in). We can now keep track of hrs in and hrs out and exactly what work was performed and by whom.
2024 JCB 35Z (A60462)
2016 KOMATSU PC360LC-11 EXCAVATOR (A60736)
2016 KOMATSU...
2017 CATERPILLAR 120M2 MOTORGRADER (A52709)
2017 CATERPILLAR...
WIGGINS 5K FORKLIFT (A58214)
WIGGINS 5K...
OVERLAND VACUUM TANK (A60736)
OVERLAND VACUUM...
2011 FORD F350 SERVICE TRUCK (A52707)
2011 FORD F350...
