L5030HST & Michelin Radials
   / L5030HST & Michelin Radials #1
mnhgolf
The forums on this web site have helped me considerably in determining which new tractor I am going to purchase. I appreciate each of you for the invaluable information you share. I, like many others will be purchasing a new L5030HST. The only options I plan to purchase are front end weights and I will have the tires loaded with antifreeze or calcium chloride. I will use the tractor for finish mowing my 5 acre yard with a heavy duty 6 foot mower and box grading the steep 1/4 mile gravel road (20% to 30% grade in some places) to my house with a 5 foot box grader. If it weren't for the steep road, I could get by with something much smaller than the 5030. I will try to purchase the tractor with out wheels and tires so that I can install Michelin XM-108 R1W tires with the appropriate wheels. It appears this tire is the best radial tire option for traction, ride, soil compaction, longevity and less visible yard damage than a typical R1 agricultural tire. My questions are:
Advantages of antifreeze vs calcium chloride filled tires?
Which Michelin XM-108 tire sizes and corresponding wheel sizes (smallest to largest - front and rear) will fit this tractor and maintain the transfer case mechanical ratio of 1.564 with a +5% to 0% lead (This specification was posted by another member)? I realize this is probably a question for Kubota and/or Michelin, but I thought I would ask in case someone else had already been down this path.
http://www.michelinag.com/agx/en-US/products/product_detail_pages/XM108.jsp
Thanks again for your wealth of information!
Mike
I think I have found the answer to my Michelin tire question, but not the tire loading question:
Front Tires: Michelin XM27: 11LR16 TL 122AB with 8x16 or 10x16 wheels
Rear Tires: Michelin XM108: 540/65R24 TL with 14x24, 15x24 or 16x24 wheels
   / L5030HST & Michelin Radials #2
Looks like a pretty cool tire; sort of like splitting the difference between R1's and R4's. I really wavered back and forth about which tire to get, the R1's or R4's. Since I do quite a bit of rough cut mowing with a rotary mower I ended up going with the R4's because it seems that everyone agrees that the R4's have a tougher carcass against punctures. So far I've been pleasantly surprised at the traction I actually get with the R4's. I've always had R1's before and was expecting to lose quite a bit with the R4's, but I didn't.
I don't know what weight bracket and weights they sell now for the L5030's, but when I bought mine I didn't like their weight bracket setup. Especially since I constantly take my FEL on and off I didn't like the fact that the weight bracket I was shown would have had to have been removed each time to put my FEL back on. I ended up making my own front weight bracket and using some JD weights I already had. Here is the front weight bracket and weights I adapted to use on the 5030. I think it cost me about $12 and took me a couple of hours to complete. Good luck!
   / L5030HST & Michelin Radials #3
Dargo... lordy, what shiney stuff you have!!! :eek:Nice job:D
I agree totally about watching how weights attach.... I had to come up with a special bracket also so I could have weights attached and use FEL as well... requires extreme planning and measuring....:eek:
   / L5030HST & Michelin Radials #4
Wow that looks showroom quality. As to the 5030HSTC, I realize it has been mighty hot of late, but I don't think my AC is working as well as it could. I made a custom blower tube so I could clean (blow out) the AC condenser and do it regularly. I also keep the filter in the cab clean and understand the controls for fresh vs. recir. air. I have also insulated the cab roof with the foil insulation. Friday it was 97 degrees and high humidity, that AC ran on highest setting for over an hour (motor RPM's @ 2000) and I never turned it down. My dealer says it is not low on freon.
   / L5030HST & Michelin Radials #5
I am wondering if you are going to be happy with a 5' box blade on the 5030. It would seem that a 6' box blade would come much closer to covering the width of the tractor which is an advantage.
MarkV
   / L5030HST & Michelin Radials #6
Good point on the 6' BB, I operate a 7' hog on my 5030.
   / L5030HST & Michelin Radials #7
Hootie, am wondering if you have a thermometer in the cab... I got one of these little outside/inside ones and installed it... no foil in cab as yet, plan to do.... A/C does seem weak lately.... haven't taken it to get coolant checked however. It was 88 the other morning outside and 109 inside when I climbed into the tractor... opened windows and let AC run full tilt.
If you have thermometer... what temp inside/outside are you able to achieve, keeping the doors closed (something I never can do because my tasks call for jumping in and out frequently) for an hour...
UNUSED FUTURE MINI EXCAVATOR GRAPPLE (A51244)
UNUSED FUTURE MINI...
43014 (A51691)
43014 (A51691)
2008 Ford F-150 Ext. Cab Pickup Truck (A50323)
2008 Ford F-150...
2018 JLG 3246ES 32FT. Scissor Lift (A51691)
2018 JLG 3246ES...
2015 Kubota MX5200F 55HP Loader Utility Tractor (A51691)
2015 Kubota...
2014 KENWORTH T680 (A52472)
2014 KENWORTH T680...
