L5030 with LOW Hydraulic Pressure
   / L5030 with LOW Hydraulic Pressure #1
FL_Cracker
Platinum Member
Palm City, FL & Blue Ridge, GA & Freedom, WY
Kubota L5030HST,R4 & Kubota RTV900R Utility Vehicle
I returned my L5030 today to have the subframe(BH90) bracket exchanged for one that was not welded up crooked. While it was there I ask that they check the system pressure as the BH & Loader seemed weak. /forums/images/graemlins/frown.gif /forums/images/graemlins/mad.gif /forums/images/graemlins/confused.gif They called back and said the pressure was low and they will try to find the problem in the morning.
Has anyone had one where the Hydraulic pressure was low and what could the problem be?
Problem solved. Dealer found the system main pressure relief valve set at 2100 psi and it should be at 2850 psi.
I jsut got a 33% increase in lifting and digging power. I think I will be able to tell the difference...
/forums/images/graemlins/smile.gif /forums/images/graemlins/smile.gif /forums/images/graemlins/smile.gif /forums/images/graemlins/smile.gif
Charles
2019 Ford F-350 4x4 Ext. Cab Palfinger PSC 3216 4,000LB 2 Ton Mechanics Crane Service Truck (A50323)
2019 Ford F-350...
2017 Ford F-550 Ext. Cab Valve Maintenance Vacuum Service Truck (A50323)
2017 Ford F-550...
International 844 Tractor (AS IS) (A50774)
International 844...
Land Honor Skid Steer Tree Puller (A50515)
Land Honor Skid...
John Deere Lawn / Garden Suitcase Weights (A50515)
John Deere Lawn /...
Livestock Stall Fan Cage (A50515)
Livestock Stall...
