L5030 Three point hitch issue.
   / L5030 Three point hitch issue.
So I bought it used this way about 3 yrs ago...
   / L5030 Three point hitch issue. #12
Does your tractor have draft control? If so check your draft control lever, and if it is ok check the draft control linkage. I had an issue with my previous tractor where I broke a control rod on the draft control and the three point would not drop. I somewhat don’t think that’s it as you said you could put weight on it and get it to drop some, but might be worth checking.
Draft control is all good. Once I took apart the valve block and studied the valves it pretty basic how draft control works (hydraulically) but yes, all connected. Thx
2017 DITCH WITCH RT30 (A51243)
2017 DITCH WITCH...
2017 Ford F-250 4x4 Knapheide Service Truck (A50323)
2017 Ford F-250...
2018 JLG 3246ES 32ft Electric Scissor Lift (A50322)
2018 JLG 3246ES...
2001 HEIL PNEUMATIC CEMENT TRAILER (A51222)
2001 HEIL...
2003 International 4300 Flatbed Truck w/ Liftgate - Inoperable - 7.6L DT466 Diesel Engine (A51039)
2003 International...
2014 UTILITY 53X102 DRY VAN TRAILER (A50046)
2014 UTILITY...
