Glenn9643
Veteran Member
Jeff,
What cylinder seems to be leaking down? Is it the top link cylinder or the side tilt cylinder? Both?
If only one cylinder seems to be leaking down try swapping the hookup at the tractor remotes. If it's the control valve the symptom should move to the other cylinder. If the problem cylinder continues to leak down it would indicate to me that it's the cylinder and not the valve. If the cylinders are only 3-4 weeks old your dealer should be able to help you remedy the problem. First, try to verify if it's the cylinder or the control valve.
