L5030 no power
   / L5030 no power #1
maxton
I need some help! I was mowing Saturday when I shut off the engine I heard a click. I went to restart the tractor and all that happened was the start relay buzzed. I checked the fuses underpass and by the battery and none were blown. The relays checked out fine as did the ignorant switch. I have no power anywhere but at the starter. Nothing else. Also there is no power going to the 30amp starter fuse in the cab fuse box, any help would be greatly appreciated!
   / L5030 no power #2
Battery connector? Ground cable?
   / L5030 no power
Thanks for replying, it's all good
   / L5030 no power
I checked battery voltage used an volt meter from battery positive you chassis. All seems good,
   / L5030 no power
OK here we go! Battery voltage is 12.9 at the posts, rechecked put under load meter went to 0! New battery,all is well! Goes to show you check the simple things first!
   / L5030 no power #6
Glad you found it. I had the cable connection to battery terminal go bad. Would show voltage, but didnt handle current flow.
2021 CATERPILLAR 259D3 SKID STEER (A51242)
2021 CATERPILLAR...
1984 NAVISTAR 1954 CABLE HOIST (A51222)
1984 NAVISTAR 1954...
TRAIL MASTER  DETROIT-TRIPLEX PUMP TRAILER (A50854)
TRAIL MASTER...
2006 Ford Crown Victoria Sedan (A50324)
2006 Ford Crown...
2022 ELITE 102" X 40' GOOSENECK TRAILER (A50459)
2022 ELITE 102" X...
2020 KUBOTA RTV...
