L5030 HST hydraulic fluid level
   / L5030 HST hydraulic fluid level #1
RobA
Platinum Member
Chester County, SE PA
Kubota L5030 HST
I just posted a message about fixing a leak in a hydraulic hose or fitting. After I sort that out how do I check the hydraulic fluid level and add more if necessary? I must be blind or something but I have been looking at the owner's manual and can not find how to do it. Thanks for the help. I am very new to this.
   / L5030 HST hydraulic fluid level #2
Dipstick and filler cap (red or pink) is behind the seat between the three point hitch. Access from the back. I check my L3430 with all the cylinders retracted - loader, three point and remotes.
ksmmoto
I saw in the manual that the transmission filler cap and dipstick are located there. Is the transmission fluid and the hydraulic fluid the same thing? Do they share the same reservoir and use the same fluid?
   / L5030 HST hydraulic fluid level #4
The transmission fluid and the hydraulic fluid are the same thing, they share the same reservoir and use the same fluid. If you need to purchase additional fluid make sure to get the Universal type that works in both the transmission and hydraulic implements.
   / L5030 HST hydraulic fluid level #5
RobA, Don't feel alone. I had the same problem you had when I first got the tractor - I could not determine, from the manual If the fluids were the same or different. The hydraulic and transmission fluid even though they have two different filters and three different drain plugs have only one place to fill and it is the UDT or the Super UDT fluid. (And a lot of it - 11.9 gallons) /forums/images/graemlins/shocked.gif
2006 GMC C7500 DUMP TRUCK (A51406)
2006 GMC C7500...
Kubota BX2680 Sub-Compact Tractor  4WD, 218 Hours (A51039)
Kubota BX2680...
2007 INTERNATIONAL 4200 SBA 4X2 DUMP TRUCK (A50459)
2007 INTERNATIONAL...
2018 Terex RL4 4000W Towable Light Tower (A49461)
2018 Terex RL4...
Deere 9970 Cotton Picker (A51039)
Deere 9970 Cotton...
1968 International Harvester 856D 2WD Tractor (A50657)
1968 International...
