I have an '03 Kubota L48 backhoe, with relatively low hours (728). For roughly the last year, I've had this intermittent dead battery/no crank issue. I pulled the alternator a few months ago, and had it tested at a starter/alternator shop. The shop said the alternator was fine, but the issue has continued. You can charge the battery, and everything will be fine. Crazy thing is, its completely unpredictable. Sometimes I can be outside running it for a couple hours, and it will crank fine...then suddenly, no crank (dead battery). Battery has been tested, and its not the issue. Coincidentally, I've noticed the glow plug "light" will some on intermittently as well, and sometimes stay on while the tractor is running.
Tractor runs like a top otherwise, and has never given us any other issues...its just this odd crank/battery issue. I've checked the terminals with the meter a couple times, and only getting 12.2-12.3v. It was doing this when I had it tested at the alternator shop, so I am curious if there is some sort of relay that "tells" the alternator to kick in/increase voltage to normal 13.7-14ish volts while turning. I did a little research on the glow plug light, and it seems like it is either the glow plug relay or controller....but I am not sure how its causing the no crank scenario (unless its simply killing the battery while running). That would sort of make sense, as I don't think there is any other 12v draw on this tractor (other than maybe lights, which are never used). Still doesn't explain, though, why I'm not getting 13+ volts with the tractor running.
The more I think about it, the more I am convinced the glow plugs are continuing to pull current with the tractor cranked, and it subsequently killing the battery...but I still can't figure out why I'm getting 12.2-12.3v with the alternator turning.
Suggestions?
Suggestions?
