3-Point Hitch L4760 HTSC rear remote kit?
   / L4760 HTSC rear remote kit? #1
fishpick
Platinum Member
The part of NY with high taxes
L4760 & BX24
I’m coming up short (life story) finding any information on a rear remote kit / install on a L4760 HST Cab model…
anyone got anything?
   / L4760 HTSC rear remote kit? #2
The only real option is Kubota OEM due to precise fitment & engineering requirements to make the fit & operate with the cab cutouts. The OEM rear valves are also notoriously leaky so that TnT cylinders leak down pretty quickly. I had many replaced, then finally gave up & had the dealer put in a DPOV on the tilt cylinder. We got an OK valve out of all the ones tried that didn't leakdown to much & used it for my toplink. I need float there so a DPOV wasn't an option.
What about install? I can’t find anything about that either. I’d hope it’s just remove the plastic trim in the cab and then install the rest from behind / underneath and you don’t have to pull the cab off the tractor!
   / L4760 HTSC rear remote kit? #4
My dealer did it. I ordered the machine with the 3 remotes. I think 6-7 ended up on the machine at various points trying to find the least bad 3 over the year or 2 I kept complaining about it.
   / L4760 HTSC rear remote kit? #5
You have to pull the wheel off to access a little metal panel that needs to come off as well. It's a tight area but not that hard to install. When I installed all 3 the hardest part, that I can remember, was holding all the valves up and trying to start the threads on the long bolts holding them all in place.
   / L4760 HTSC rear remote kit? #7
Best bet is to talk to your dealer, its multiple kits with various valve options and is sold through the wholegoods catalog so you'll need to talk to a salesman, not the parts department.
Sent from my SM-G715U1 using TractorByNet mobile app
I figured. I sent an email to Messicks and they didn’t reply. So - back to the local guys!
   / L4760 HTSC rear remote kit? #9
If I remember correctly.....the base kit was L8398, the second position kit was L8393, and the third position kit was L8394. Each requires a valve in addition to the kits. The double acting valve was L8308 and the Float detent valve was L8309.
Hope that helps.
Vermeer SC802 (A50322)
3000 Gallon Black Poly Water Tank (A49461)
3000 Gallon Black...
2011 Ram 1500 4x4 Crew Cab Pickup Truck (A50323)
2011 Ram 1500 4x4...
2025 Swict 84in Bucket Skid Steer Attachment (A50322)
2025 Swict 84in...
2005 Ford F650 Fire Truck (A49461)
2005 Ford F650...
2011 L3 MEP-806B GENERATOR (A51222)
2011 L3 MEP-806B...
