Front-End Loader L4740 kubota loader dump position is very slow.
   / L4740 kubota loader dump position is very slow. #1
alvadude
kubota L4740
has anyone replaced the seals for the bucket tilt cylinders,if so which seal kit fits a la854 model with sn a3492?
   / L4740 kubota loader dump position is very slow. #2
Does the bucket curl out by itself? Is your joystick valve cabled between the stick and valve? If so it sounds more like a cab,e out of adjustment than a piston seal leaking by.
   / L4740 kubota loader dump position is very slow. #3
As others will say, check your quick connect fittings and make sure all are seated. If one function is off it is usually one of those. If the same cylinder has problems going either way then I would look at the internal seal.
David
PULL TYPE CONCESSION STAND (A54757)
PULL TYPE...
2 - WEATHER GUARD TOOLBOXES (A55745)
2 - WEATHER GUARD...
2018 Freightliner Bucket Truck (A55973)
2018 Freightliner...
2010 Chevrolet Tahoe SUV (A56859)
2010 Chevrolet...
2008 Toyota Rav 4 SUV (A56859)
2008 Toyota Rav 4...
2014 Doyle Dry Fertilizer Tender Trailer - Kubota Diesel, 3 Stainless Compartments, Side Discharge (A56435)
2014 Doyle Dry...
