Front-End Loader L4740 kubota loader dump position is very slow.
   / L4740 kubota loader dump position is very slow. #1
alvadude
kubota L4740
has anyone replaced the seals for the bucket tilt cylinders,if so which seal kit fits a la854 model with sn a3492?
   / L4740 kubota loader dump position is very slow. #2
Does the bucket curl out by itself? Is your joystick valve cabled between the stick and valve? If so it sounds more like a cab,e out of adjustment than a piston seal leaking by.
   / L4740 kubota loader dump position is very slow. #3
As others will say, check your quick connect fittings and make sure all are seated. If one function is off it is usually one of those. If the same cylinder has problems going either way then I would look at the internal seal.
David
UNUSED MOWERKING QUICK ATTACH BRUSH CUTTER (A51244)
UNUSED MOWERKING...
2015 Ottawa Yard Spotter Truck - Cummins Diesel, Allison 6-Speed, Hydraulic Air Fifth Wheel (A52128)
2015 Ottawa Yard...
CLASS ROLLANT 160 HAY BALER (A51243)
CLASS ROLLANT 160...
TRAILER AXLE (A51244)
New Holland TS6.120 4WD 96HP Agricultural Tractor (A50322)
New Holland...
12 ft Chisel Plow with Rolling Baskets (A52128)
12 ft Chisel Plow...
