L4701 error code flashing, it is either a “PO563” or a “POS63
   / L4701 error code flashing, it is either a “PO563” or a “POS63 #1
pughde
Easley, SC
Pulled trigger on 2360
Ok, I have a K4701 with 150 hours. I left the key in and on, and ran down the battery. Tried to charge it in the tractor, tried several different charges none would allow the battery to be fully charged, like 25%. I can start it and it runs but battery seems a little weak. After a while I started getting an error code flashing, it is either a “PO563” or a “POS63, can’t tell for sure. Should I try to reset the error not sure how?
Any comments and suggestions will be appreciated
   / L4701 error code flashing, it is either a “PO563” or a “POS63 #2
Look here
   / L4701 error code flashing, it is either a “PO563” or a “POS63 #3
PO= Piece of and POS = Piece of (you fill in the blank)..... :p
   / L4701 error code flashing, it is either a “PO563” or a “POS63 #4
If you can only charge it 25%, you either need a better battery charger, or a new battery
I plan to take it to a battery place to test it. Getting it out may take me some time, does not look easy.
   / L4701 error code flashing, it is either a “PO563” or a “POS63 #6
Test it yourself. Got to HF and buy a carbon pile load tester, I think they are about 30 bucks.
Picked up the new battery from the Kubota dealer, still getting the error code POS63. I may need to reset the code, will call the dealer tomorrow.
Utility Trailer (A52377)
Utility Trailer...
1996 Allegheny 35ft 25 Ton Flatbed Equipment Trailer (A51692)
1996 Allegheny...
GRADALL XL3100IV MOBILE EXCAVATOR (A51406)
GRADALL XL3100IV...
2022 CATERPILLAR 242D3 SKID STEER (A51406)
2022 CATERPILLAR...
2 windsor 351 inboard motors w/transmissions shafts rutters and props (A53424)
2 windsor 351...
2020 NISSAN Versa Sedan (A53424)
2020 NISSAN Versa...
