L4600 heater problems
/ L4600 heater problems #1
urd505
Kubota L4200GST
I have an L4200 heater won't heat,I've replaced the thermostat,didn't help...
I checked,it don't have a valve where the hoses connect
/ L4600 heater problems #4
Few things that we need to look at here.
First off, is the engine getting up to normal operating temp? What's your temp gauge say?
Once things are warm, see if you're getting any water through to the heater core. AKA, check to see if those lines get warm.
If the fan blowing? You may also need to look at the damper door to see if it is directing air through the heater core.
2014 Lincoln MKS Sedan (A64557)
2014 Lincoln MKS...
1990 FRUEHAUF 53' DRY VAN TRAILER (A64280)
1990 FRUEHAUF 53'...
Hesston 3717 Hay Tetter (A65640)
Hesston 3717 Hay...
(2) 10ft Nesting Boxes (A65579)
(2) 10ft Nesting...
(4) Hydraulic Cylinders (A65640)
(4) Hydraulic...
2016 KUBOTA SVL90-2 SKID STEER (A65053)
2016 KUBOTA...
