L45 Transmission issues
   / L45 Transmission issues #1
srl28
We have a 2010's Kubota L45 that has a trans issue that has progressively gotten worse. We had issues with the HST peddle sticking or needing to be pressed in an exact way in order for the machine to be started. Had our local dealer basically rebuild the pedal, little springs inside and out of it, and some of the linkage that had rusted, etc. However, in addition to that we have noticed that the machine tends to lurch backwards, sometimes forward, although backwards seems to be most common when just sitting there at idle. If you leave it at idle in an open lot it will be on the other side of the lot in a few minutes. If the parking brake is on it will just strain to move against the parking brake. We have resorted to putting the machine in neutral when we aren't on it to avoid any accidents, etc. Also seems to be some hesitation to move forward when the peddle is pushed forward, like the peddle is out of adjustment.
Our local dealer mentioned that there are two solenoids on the exterior of the transmission, one for forward, one for reverse that at this point in time, salt, wear and tear, etc. probably are out or on their way out and recommended we start there by replacing them.
When it was in the shop for the peddle work, they noticed a leak from the center of the machine and determined that the tractor/case needs to be split and some seals replaced. Something that they need the machine for about 2-3 weeks for and about $3k+. Their other comment when we brought up the lurching forward/reverse issue is that maybe the leak is causing oil to splash on the clutch plate and other components and effecting the whole lurching issue. Although this doesn't seem to be the case, I figured it was worth mentioning. Machine has about 1400 hours on it. Relatively well maintained but has been used commercially in landscaping and snow removal so its seen its fair share of salt, mud, etc.
I'm leaning towards that solenoid being the problem but wanted to see what anyone else thought.
   / L45 Transmission issues #2
You are doing the right thing getting more input, from sites like TBN, or OTT, or maybe from more experienced dealers.
My HST experience is with the type just before they went to solenoid valves for F-R control. But with either manual or solenoid control, its way safer to shift any machine into neutral before allowing it to idle without an operator.
The unexpected engagement of F or R sounds more like corroded/shorted control wiring. Solenoid valve malfunction is not unheard of on these machines. Maybe search here and on OTT for HST engagement symptoms.
Trans fluid leaking may eventually affect performance, but would not be expected to cause errant shifting. I'd concentrate on fixing the control issue first & go after the leaks later. Splitting the machine before being sure whether its actually necessary can be hard on your checkbook. Maybe someone else will chime in. Best luck, Dick B.
   / L45 Transmission issues #3
Sounds like your HST is drive by wire like my M59. I started having bog down and funky hesitation drive issues on mine. Dealer service manager suggested an electrical issue and I try to clean the contacts on the solenoids as they were back logged a couple of weeks in service. He said machines exposed to road salt clearing snow can have fwd/rev solenoid issues. Said bog downs likely due to both fwd and rev solenoids simultaneously activating or not releasing properly.
I traced all the wires and cleaned the harnesses connectors and contacts from the HST pedal to the solenoid. Issue resolved.
   / L45 Transmission issues #4
keep an eye on the leak it will get worse and eventually turn into a gusher and may end up running the transmission dry and ruining the tractor.
I dont know if the L45 is the same but paul shorts has a video about the roller bearings on the linkage getting stiff and causing issues.
having someone actuate the pedal with engine off while you are looking around underneath at the linkage may help you figure things out
197637 (A50459)
197637 (A50459)
2014 Doyle Dry Fertilizer Tender Trailer - Kubota Diesel, 3 Stainless Compartments, Side Discharge (A52128)
2014 Doyle Dry...
2006 Kenworth T600 Semi (A50514)
2006 Kenworth T600...
Land Honor Quick Attach Vibratory Plate Compactor (A50514)
Land Honor Quick...
John Deere 8430 Track Tractor (A50514)
John Deere 8430...
2016 Ford Explorer...
