L45 Tiller Size
   / L45 Tiller Size #1
PsRumors
Cartersville (NW) Georgia
Kubota L45
Anyone running a tiller behind their L45? Wondering if it will power a 6' since it only has 32 PTO hp. How about a 6' bush hog as well?
   / L45 Tiller Size #2
Are you interested in a forward or reverse tine rotation tiller?
A light duty 6' bush hog weighs around 475 pounds, medium duty 650 pounds, heavy duty 1,000 pounds.
What do you intend to mow? Got hills to mow?
Appears time to update tractor ownership in your T-B-N PROFILE.
   / L45 Tiller Size #3
I have a 5' forward rotation King Kutter. It ran ok behind my L3200. Could have used more power, but HST kept it going well. It matched width properly. I still run it behind my L4060HSTC. 6' 40hp tractor so it's a little wide, but it works well enough I dont upgrade. Mostly doing arena maintnance with it these days. A 6' behind the L4060 machine would probably be ok rather than good, but wouldnt have issues not covering my tracks.
Reverse rotation is fighting the tractor & hence takes a bit more power to run. Forward rotation helps push the tractor. I hear reverse buries material better though. Never had an issue with my forward rotation though.
   / L45 Tiller Size #4
I run a 6 foot bush-hog on mine with no problem, don't have a tiller so can't help there.
   / L45 Tiller Size #5
IF you are just going to do some garden spots and you have a lighter duty tiller, you will be fine. But, if you buy something like a Howard of Kuhn tiller, and want to do larger area's like fields, you will be under powered and probably over heat your tractor.
SR
2013 Nissan Rouge SUV (A56859)
2013 Nissan Rouge...
CASE TV370B SKID STEER (A52706)
CASE TV370B SKID...
2014 FREIGHTLINER CASCADIA (A58214)
2014 FREIGHTLINER...
1992 DFI PULL SPREADER (A57192)
1992 DFI PULL...
1453 (A57192)
1453 (A57192)
Year: 2017 Make: Dodge Model: Charger Vehicle Type: Passenger Car Mileage: 105,664 Plate: Body Ty... (A56859)
Year: 2017 Make...
