Loader L45 4N1 hesitation then inop
   / L45 4N1 hesitation then inop #1
workinallthetime
Tulsa, ok
L45 TLB, ZD326P
Just thought i would share a experience i had with my new -200 hrs L45
i noticed the 4N1 bucket was acting a little weird, the operation was delayed and at time for lack of a better term "jumpy". i continued to operate it as the condition would come and go until it quit working in one direction all together.
i traded the lines and the function would work in reverse, so i went to the electrical aspect
i found the connectors under the deck for the switch and tore down the handle, i used a meter and measured the resistance of the ckt from the handle to the connectors, 3 of the 4 wires were open.
i pulled the plastic protective cover off the wires and found a spot in the wires that looked suspect, flat, as i pulled each wire they strung out and broke. the wires were broke inside their jacket, a few heat shrink but connectors later and all was working again. the 4th wire that had tested good was also about to break so a repair was made there also.
i suspect when the dealer installed the handle they pulled way to hard on the wires to get them in the handle.
maybe this will help someone down the road
   / L45 4N1 hesitation then inop #2
Thank you, as we don't see a whole lot on here about l45's. Hope that's a good thing in a way.
2020 DRAGON ESP...
2010 Freightliner Derrick Digger (A55973)
2010 Freightliner...
7021 (A55851)
7021 (A55851)
11 ft Shipping Container (A55973)
11 ft Shipping...
Deere 310L (A53317)
Deere 310L (A53317)
2017 Ford Explorer AWD SUV (A56859)
2017 Ford Explorer...
