Loader L45 4N1 hesitation then inop
   / L45 4N1 hesitation then inop #1
workinallthetime
Veteran Member
Tulsa, ok
L45 TLB, ZD326P
Just thought i would share a experience i had with my new -200 hrs L45
i noticed the 4N1 bucket was acting a little weird, the operation was delayed and at time for lack of a better term "jumpy". i continued to operate it as the condition would come and go until it quit working in one direction all together.
i traded the lines and the function would work in reverse, so i went to the electrical aspect
i found the connectors under the deck for the switch and tore down the handle, i used a meter and measured the resistance of the ckt from the handle to the connectors, 3 of the 4 wires were open.
i pulled the plastic protective cover off the wires and found a spot in the wires that looked suspect, flat, as i pulled each wire they strung out and broke. the wires were broke inside their jacket, a few heat shrink but connectors later and all was working again. the 4th wire that had tested good was also about to break so a repair was made there also.
i suspect when the dealer installed the handle they pulled way to hard on the wires to get them in the handle.
maybe this will help someone down the road
   / L45 4N1 hesitation then inop #2
Thank you, as we don't see a whole lot on here about l45's. Hope that's a good thing in a way.
(8) 2 PLUG VALVES (A52472)
(8) 2 PLUG VALVES...
2003 FORD E-350 (A50323)
2003 FORD E-350...
Gehl RT210 Turbo Skid Steer Loader (A50514)
Gehl RT210 Turbo...
2011 Ford Crown Victoria Sedan (A51694)
2011 Ford Crown...
