L4400 three pint hitch problem?
   / L4400 three pint hitch problem? #1
some zilch
Hello, after research through this forum, i have purchased a new L4400. It has a FEL, and 1 rear remote. It is gear drive. It now has 1.2hrs on it.
I also got a rear scraper blade for it, which i picked up today (they were sold out at the time i got the tractor). Anyways, i got it home, and went to hook it up to the tractor. I lowered the TPH arms, they lowered very slowly, and i hooked them up to the blade. I hooked up the top link. I moved the control lever to the "raise" position, and the blade did not raise, it didnt even try to. I messed with the control know under the seat, and it made no difference.
Since i have a rear remote, when i move the remote's control lever to either position (as in not neutral), shouldnt the hydraulic system "deadhead" if nothing is plugged into the remotes? Mine does not do anything.
Does it matter if my FEL control valve is in "float" position when trying to operate TPH functions?
I am a heavy equipment mechanic by trade, so i am not a total dummy when it comes to this stuff, though i have never owned a tractor like this before. I work on lots of bobcats, so i understand hydraulics and remotes and such, which is why i was curious about "deadheading" when nothing is plugged into the remotes.
Am i missing something really obvious as to why my TPH wont raise? i dont want to look like a total dummy when i call the dealer and start complaining.
   / L4400 three pint hitch problem? #2
Zilch,
The hitch valve has an unloading valve built into it. When you move the handle to raise, there is a land that ports some fluid to the backside of the unloading spool to closse it and effectively plug the leak. The fluid is then sent to the cylinder port of the valve and the hitch raises until the external followup linkage pulls the main spool back to neutral. You can adjust the rod to change when this happens. When the hitch is in neutral, the fluid behind the unloading poppet is released, and the poppet backs up to allow the fluid to dump to tank.
The auxilary valve is parallel to the hitch supply so the only way to load the system is by dead heading the valve.
Good luck!
2003 Big Tex 10PI 16ft. T/A Pipe Top Utility Trailer (A49461)
2003 Big Tex 10PI...
72in Rock Bucket Skid Steer Attachment (A50322)
72in Rock Bucket...
2004 INTERNATIONAL 4300 CARGO TRUCK (A50854)
2004 INTERNATIONAL...
ALL TITLED ITEMS HAVE A $35 TITLE FEE!!! (A50775)
ALL TITLED ITEMS...
100 GAL FUEL TANK (A50854)
100 GAL FUEL TANK...
2015 MACK GU713 (INOPERABLE) (A50854)
2015 MACK GU713...
