Bob_Young
Veteran Member
- Joined
- Jul 5, 2002
- Messages
- 1,244
- Location
- North of the Fingerlakes - NY
- Tractor
- Ford 4000; Ford 2000(both 3cyl.);JD40; 2004 Kubota L4300; 2006 Kubota B7610; new 2007 Kubota MX5000
Roger, the 134 c.i. 4 cylinder engine they use in the L4400 is quite common in the Kubota line and has been used in a number of tractors and at least one excavator. My L4300 has one and I like it a lot. Very easy starting, very smooth and doesn't use much fuel. I don't think you could make a better choice.
I have noticed that it does like to be worked hard, however. If I just putter around with it for a few weeks, especially in cold weather, it'll begin to use a little oil. If I then work it hard for an hour or so, it'll blow a little blue smoke at first, then settle down, and oil consumption will stop. I figure carbon builds up around the rings if it isn't being worked. It'll do plenty of useful work at idle speeds, but it isn't meant to be run that way
I'd go for the loaded rear tires for sure but, with Ag tires, it will definitely chew your lawn up.
Might be time to trade that 7000# trailer; I haul the L4300 on a 10,000# 20 footer. You'll need that if you take any implements with you. Whatever you use should have trailer brakes.
That price sounds quite high. I'd expect an L4400HST with FEL and your options to run $21K to $23K tops (U.S.D.) in this area.
FWIW
Bob
FWIW
Bob
