L4400 3ph lift only??
/ L4400 3ph lift only?? #1
cityfarma
Western Australia
Kubota L4400
As a new player with a new toy, I was wondering if it is normal for my 3ph to have no down pressure. With the control at the lowest point, I can lift the lift arms. Is this normal a) for L4400, b) other brands?:confused:
If normal, I suppose the weight of the implement is what drives equipment into the dirt.
Cityfarma
/ L4400 3ph lift only?? #2
Yes they ONLY lift. Gravity does the rest. And yes, with the arms lowered, you can lift them by hand.
/ L4400 3ph lift only?? #3
As tydp said there is now down pressure on the 3 ph, just the weight of the implement brings it down.
/ L4400 3ph lift only?? #4
You'll be happy that they lift easily by hand when you're hooking up implements.
/ L4400 3ph lift only?? #5
Yes they until you get one side hooked and and need about another inch to raise to get it on the pin.
Stout Brush Grapple HD72-4 (A66285)
Stout Brush...
ROANOKE S/A LOOSE LEAF TRAILER (A63291)
ROANOKE S/A LOOSE...
1992 International 8200 Spreader Truck, VIN # 1HSHEDPN2NH418329 (A65563)
1992 International...
Great Plains 7326DH (A64126)
Great Plains...
2018 Trail King Lowboy (A63689)
2018 Trail King...
2008 INGERSOLL RAND G240-191KW GENERATOR (A63276)
2008 INGERSOLL...
