L4350
   / L4350 #1
97hokie
I am looking into a used tractor for replacing a bobcat around the farm. I do not have much expierence with Kubota's but have found a good looking 4350 with only 600 hrs on it. It has a shuttle trans, but I do not know what this really means(only have had geared tractors in the past). i will be using it for light bush hogging, trail maintence, a bit of skidding wood and hopefully will put a grapple attachement on at times. The bobcat is just not used enough and I have a track loader for the large jobs around here. I have read a few good things about the 4350, but I don't seem to see many for sale to get a good idea of cost. The one I am looking at is $14k any help or insight on the model would be appreciated.
   / L4350 #2
I have a l4350... Ben a very good Machine!
   / L4350 #3
I have one as well, a tank of a tractor. It is a gear drive with hi/lo range. The shuttle shift usually is hydraulic, at least mine is. You may have the everclutch as well which is a wet clutch. Should have an LA950 loader on it. Again, a very tough tractor. Just make sure you check the shuttle for good forward and reverse action, they can be expensive to repair.
   / L4350
thanks for all the info so far. The tractor seems to be in good condition, and everything looks right, but I have no idea how to check the shuttle(Which it does have to left of the seat). How exactly would I go about this? also is adding a quick connect to the loader difficult? currently it just has a fixed bucket.
2005 Ford F-150 Ext. Cab Pickup Truck (A50323)
2005 Ford F-150...
RoGator RG1100C (A51039)
RoGator RG1100C...
UTV (A49461)
UTV (A49461)
2018 FORD F-550XL SERVICE TRUCK (A51406)
2018 FORD F-550XL...
Great Plaines 2400 Tt (A50514)
Great Plaines 2400...
Drill Bit attachment (A50322)
Drill Bit...
