L4330 with BH92
   / L4330 with BH92 #1
Mickcorp
Kubota L4330, Kubota Bx23S
Hello all, I’ve used this site for a resource for quite some time. I decided to sign up so I can ask questions I can’t find threads on.
Anyway, we have a Kubota L4330, we’d like to add a BH92. I can’t find anything clear about whether the current BH92 will mount to the non-current L4330. I’m gathering the BH4999 might be the subframe I’m looking for. I’m also gathering I need extensions because of the cab. I just can’t confirm this.
The dealer here isn’t all that clear on it either. They were pushing us in the direction of a Wallenstein GX720, because they show a clear option for a subframe for our tractor.
Looking for someone who has successfully made this combination, and wondering if there is much to it.
**Also I know it’s not an excavator replacement, but the cost of a mini is not in the cards. This unit will do what we need.
Thanks in advance,
   / L4330 with BH92 #2
The BH would mount up to the factory subframe and you would need the extensions for the cab, however you might not be able to get the factory subframe. On my L3240 the BH subframe is apparently NLA, I lucked out and was able to buy a NOS from a dealer that was closing down (actually 2!) but that is pretty unusual.
Sent from my SM-G715U1 using TractorByNet mobile app
   / L4330 with BH92
Ok, that was one concern, Kubota had the subframe at one point but no longer makes it … thanks for the reply
   / L4330 with BH92
Would you happen to recall the subframe model ?? Thanks
   / L4330 with BH92 #5
I don't, but I'm pretty sure they are different from the larger grand L's.
   / L4330 with BH92 #6
   / L4330 with BH92
I’ve read good things about the woods brand, just not sure they’re available here. I’m in Northern Ontario.
1964 Mercedes-Benz 190D Car Sedan (A56859)
1964 Mercedes-Benz...
Deere 335P (A53317)
Deere 335P (A53317)
2022 RAM 2500 HEAVY DUTY (A55745)
2022 RAM 2500...
2021 Allmand Bros Maxi-Lite II 20kW Towable Light Tower (A55973)
2021 Allmand Bros...
2004 Pierce Tilt Crew Cab Enforcer Fire Truck (A55853)
2004 Pierce Tilt...
Hose Reel (A55758)
Hose Reel (A55758)
