L4310's and very steep hills
   / L4310's and very steep hills #11
Re: L4310\'s and very steep hills
Mark, After my 50 hrs it looks like i will be switching to amsoil in the hyd. so i will put in a little extra. I have 300 lbs. in cast iron wheel weights and about 1100 lbs of that new rim guard. I had a 72" tiller on the back. Air psi is at 10 lb. in the rear and 45 in the front. Surface was sand and small gravle/stone but mostly sand.
Rich
   / L4310's and very steep hills #12
Rich the rim guard is that beet juice isn't it? Is it expensive compared to other tire fills?
How bout letting me borrow that tiller?/w3tcompact/icons/smile.gif
Gordon
Rich - It sounds like you've got the right setup, as far as I've been able to come up with, anyway. But I sure don't understand your losing traction. It must just be that the surface was too loose. There's no such thing as traction when the surface you're on won't stay in place.
MarkC
   / L4310's and very steep hills #14
About adding more fluid to the case, I would be concerned about pressure buildup, and possibly blown seals. I would hesitate to do so without thorough research, and preferrably someone else's tractor!
40' CONTAINER (A52706)
2011 Audi Sedan (A56859)
2011 Audi Sedan...
2015 GENIE S-45 TELESCOPIC BOOM LIFT (A52709)
2015 GENIE S-45...
2022 Caterpillar 906M Compact Articulated Wheel Loader (A56857)
2022 Caterpillar...
2012 NISSAN Rogue (A56859)
2012 NISSAN Rogue...
2013 Ford Taurus SEL Sedan (A56859)
2013 Ford Taurus...
