L4310
   / L4310 #1
VTPlumber
Vt.
N/A
I am going to look at a 2000 L4310 FWD with 523 hours on it this saturday.
The tractor has a L681 FEL and also a backhoe
Does anyone know what the engine and PTO HP is on this and also what the lifting capacity of the FEL is.
The backhoe make and transmission type are unknown at this time but the asking price is 20,500
Does this sound reasonable?
Is there any way to tell if the hour meter is correct?
Any certain things to look out for with this model?
Any comments on the tractor would be appreciated
   / L4310 #2
Net engine hp = 43.0
PTO hp = 37.5 with gear tranny, 36.0 with hydro
FEL lift cap at pivot pin = 1786 lbs
at bucket center = 1499lbs
breakout force = 2583 lbs
What kind of backhoe is it? 3pt or subframe? Brand?
What was main use of the 4310? Commercial use (not likely at only 500 hrs!)? If heavy loader use, check front axle for wear.
These are very reliable tractors. If given reasonable use and maintenance, it should be just getting broken in at 523 hours.
If it's in good shape, $20,500 isn't bad for tractor, FEL and BH.
2020 PETERBILT 567 (A58214)
2020 PETERBILT 567...
Wolverine Quick Attach Skidsteer Grapple Bucket (A59814)
Wolverine Quick...
JOHN DEERE 544G WHEEL LOADER (A58214)
JOHN DEERE 544G...
MARATHON 20KW GENERATOR (A55745)
MARATHON 20KW...
205196 (A52706)
205196 (A52706)
2023 Caliber Trailers GH840MST 40ft T/A Gooseneck Flatbed Equipment Trailer (A55851)
2023 Caliber...
