Mowing L4300 with 84" finishing Mower
   / L4300 with 84" finishing Mower #1
Lynn_O
L4300 with 84\" finishing Mower
I am looking at buying a L4300 with HST. I believe it has a
PTO hp of 29 or 27. Most 84" brands call for a min. of 30 HP
at PTO. How crucial is this. I will be mowing almost flat ground
all the time about 5 acres. And will be keeping it cut low once
every 7-10 days, bermuda grass. Do you guys think the L4300
will be enough HP with HST. If not what do you think i need.
even if its a different brand !
   / L4300 with 84" finishing Mower #2
Re: L4300 with 84\" finishing Mower
This Kubota web page lists all of their prior models. You'll find the L4300 under the Basic L Series, and it shows PTO HP to be 37.5. I'm sure it will handle a 7' RFM.
edit - Here are the complete specs, from a dealer's website.
Ok, let me try this again, Sorry, i did not have my info in
front of me at the time. I meant a L 3400 which list the
hp at 29.7 gross and 27.0 at PTO for HST models. with
that in mine, i refer back to my first questions, thanks.
   / L4300 with 84" finishing Mower #4
I use 72" FM with L3130 HST, and the tractor doesn't know it is even there. I used to use 72" with 20 HP tractor no problems, I would think you could do it.
   / L4300 with 84" finishing Mower #5
I pull a 72" with a B7610 at work, 24 hp engine 18 or 19 hp pto. I get along quite well at reasonable speeds 5mph or so on flat ground I'd have the power to go faster but it's a bit rough. On hills I do have to slow a bit but not unless it's real steep or I let the grass get excessively tall. I can't see a 28 pto hp tractor not pulling a 84" in the conditions you describe. Your looking at 10hp more and only 1 FT more mower. It should work.
(APPROX. 11) JOHN DEERE PLANTER FRAMES (A58374)
(APPROX. 11) JOHN...
Unused 84" Bucket Attachment (A55272)
Unused 84" Bucket...
2011 ROCKWOOD ULTRALITE 5TH WHEEL CAMPER (A52708)
2011 ROCKWOOD...
(2) Seats (A57149)
(2) Seats (A57149)
2018 Ram ProMaster 2500 Passenger Van (A56858)
2018 Ram ProMaster...
1979 KENWORTH TANK TRUCK (A58214)
1979 KENWORTH TANK...
