L4200 3pt lever creep
   / L4200 3pt lever creep #1
Jay4200
Veteran Member
Hudson/Weare, NH
L4200GST w/ LA680 & BX2200D w/ LA211
While operating my tractor this past weekend, I noticed the 3ph lever tended to creep toward the down position a half-number or so while pulling my landscape rake. The 3ph has position control and it usually stays exact when I set a position, the lever also seems 'looser' than it was.
I found a little rubber tube where I park my tractor a couple of weeks ago - maybe an inch long and 3/8" wide. I wonder if something fell off that was important.
   / L4200 3pt lever creep #2
Easy - on the lever's shaft there's a nut and a jam nut for setting how much "drag" the lever has. They need adjusting now and then as the cupped washers wear.
2016 GMC Terrain SLE1 SUV (A50324)
2016 GMC Terrain...
2 Vintage Metal Signs (A48081)
2 Vintage Metal...
1973 CATERPILLAR 988 LOADER (A51222)
1973 CATERPILLAR...
2014 Volkswagen Passat Sedan (A50324)
2014 Volkswagen...
2007 CAT 904B (A47384)
CFG MH12RX Mini Excavator (A49461)
CFG MH12RX Mini...
