L4150 front end querry
   / L4150 front end querry #1
redman135
nz
Case 105c
Hello, I have spotted a L4150 for auction. Ihave never had anyhing to do with a kubota before. It states "front driveshaft removed, and steering needs work". Can any one tell me why these parts fail, ie weak, old age etc?
   / L4150 front end querry #2
I would guess lots of hours and not much grease. Many a good tractor has went to an early grave due to dry grease fittings. :(
Keefer
Thanks KubotaGlocker.
   / L4150 front end querry #4
Tractor routinely operated without a counter-balance on the Three Point Hitch while doing heavy FEL work.
I would check the engine and transmission fluids at once. People that fail to counter-balance are unlikely to keep up on routine maintenance.
How many hours show on the engine meter?
Another possibility is a front end collision. Or several front end collisions.
   / L4150 front end querry #5
The L4150 was a very robust model - failures in the front drive were very rare, usually from gross abuse. Removing the front driveshaft would mask a broken gear that makes noise when shifted into 4wd. A steering issue could be bent or broken tie rods, pitman arm, etc, or failed hydraulic steering box ($$). I'd guess the bids will be very low. Pretty important to have a close look unless it's under $2-3k and you're adventurous. BTW the hour meter cable on these routinely breaks at around 1000 hours - can only estimate actual hours from overall condition.
2018 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER (A51222)
2018 FREIGHTLINER...
2012 Chevrolet Traverse SUV (A50324)
2012 Chevrolet...
1996 Chevrolet IMPALA SS (A51222)
1996 Chevrolet...
2021 Ver-Mac PCMS-3812 Solar S/A Towable Trailer Message Board (A49461)
2021 Ver-Mac...
STS MUD MIXING MACHINE (A50854)
STS MUD MIXING...
SERVICE BODY BED W/CRANE (A50854)
SERVICE BODY BED...
