Hiawassee Longhorn
I have an 2023 L3902 I got at the beginning of June.  I got R1 tires w/fluid set at the middle width setting on it an FEL, rotary mower and a rototiller.  My last tractor was an 25hp LS with R4 tires w/fluid FEL and a detachable factory backhoe both this tractor and the LS are the same physical size only difference obviously is the engine size and the tires. However this tractor is so tippy I can't even pick up a bucket load of gravel without the tractors rear end coming off the ground.  The LS had no problems completing the same task.   I've almost dumped this tractor 4 times now doing meanial tasks that should not cause a tractor of this size any issues.  The only was I've managed to keep it from tipping is to have my rotary mower attached and as low as I can get to the ground all the time.  But even then it's still feels unstable.  What am I missing or is this the way they are?
