L3901 HST Noisy in Reverse
   / L3901 HST Noisy in Reverse #1
North Woods
Outside of a village with no cell phones.
Yard Man Mow-dozer, & Kubota L3901
Just picked up a used 2015 L3901 with 10 hrs on it. :dance1: (There is a story.)
Three questions:
1. During my first 6 hours of use I noticed the transmission would make a louder and more harsh whining noise when backing up. This is above the normal HST sound when moving forward. I searched the forums before posting and noticed that the 3301 and 3901 can have this characteristic but it seems to be hit and miss. I am checking with the dealer to see if all applicable tech bulletins have been applied. It is appreciably louder in reverse than forward and not sure what is normal and what is not.
2. During reverse there is a tinny rattling sound. Kind of like a thin shield is loose somewhere. Location seems to be just forward of the operator station or the rear of the engine compartment area. Definitely down lower in the chassis. It seems to be more prominent when starting or under a load although that is just a feeling at this point. It has not been verified but I can reproduce it when starting to move. This does not occur when going forward.
3. Finally I noticed a ticking noise in the transmission proportional to the engine RPM. It would go away if the clutch was depressed. Otherwise it could be heard if in 2WD, 4WD, in L, M, or H range or neutral. My initial 6 hours did not include any ground engaging equipment so the PTO was not used. I came back to check it the next day and the sound no longer occurs nor have I been able to reproduce it.
All operations were at or below 1900 RPM. So, two whines (plus the new owner) and a non-existent tic. Any insights will be appreciated.
Thanks.
   / L3901 HST Noisy in Reverse #2
1. Normal. Most all HSTs whine.
2. Could be anything.
3. Not sure. If you can't reproduce it, then wait and see if it comes back.
I wish I had your L3901... that is the model I am eyeing up for my upgrade.
"I wish I had your L3901... that is the model I am eyeing up for my upgrade."
Thank you for the help Diesel. It is a little small for what I was looking for but has done everything I have asked of it (other than get unstuck.) I added fluid to the tires, and blade, grapple and loader. Think it is about 4400 lbs. The six hours were spent mostly uprooting small stumps and root balls. I was fortunate to get this one just before the stampede. If I come across another one like this I will let you know.
   / L3901 HST Noisy in Reverse #4
Is the tractor still under warranty?
TORO SAND PRO 3020 (A58374)
TORO SAND PRO 3020...
2013 KUBOTA SVL90-2 SKID STEER (A52709)
2013 KUBOTA...
VINTAGE MERCURY MODEL K OUTBOARD MOTOR (A58374)
VINTAGE MERCURY...
2014 Chevrolet Silverado 1500 High Country 4x4 Crew Cab Pickup Truck (A56858)
2014 Chevrolet...
2005 CATERPILLAR 262B SKID STEER (A52709)
2005 CATERPILLAR...
UNUSED FUTURE FT380 STAND ON SKID STEER (A52706)
UNUSED FUTURE...
