L39 TLB
/ L39 TLB #21
No. Too many small issues (minor leaks, noisy trans). Decided to look for something a little newer and spend a little more money. Still looking to pull trigger. Getting by still with my NH1715 but still looking for that machine with backhoe.
Buy a machine with 1000- 2000 hours, in good overall condition.
You will never be sorry that you did.
/ L39 TLB #22
I wouldn’t be scared of a Kubota TLB with 1000 hours but it better be a good deal at 2000. IMO they don’t share the same build quality as a full size hoe and the better days are behind it by 2000. My 310 had 2600 hours and aside from some minor sun fade it was the same as new.
/ L39 TLB #23
Sounds like you made the right decision. IMHO that is a lot of hours for a TLB, although we can fix nearly anything, there is only so much time in the day!
/ L39 TLB #24
Well.....maybe......but my Kubota L48 is at least equal in build quality to the JD 110 TLB.
Actually......better, in my opinion, as the JD has some reported issues.
/ L39 TLB #25
I’d take a Kubota over a 110 any day. But the 310 is a more durable unit. I see them with 7/8000 hours pretty often.
/ L39 TLB #26
With my L48 at a whopping 252 hours, and me at almost 79 years, I think I'm safe with Kubota longevity.
/ L39 TLB #27
And the Kubota TLBs don't cost as much either new or used. To me, when something in the compact tractor line gets up around 4000 hours that doesn't mean that it is going to fail or even that it has significant wear. In fact, we could argue that at that many hours sudden surprises are unlikely. But at 4000 hours everything about it simply depends on the way it was used and maintained.
Our old JD310 TLB has 5700 hours on it and it definitely shows wear and some looseness - mostly on controls surfaces and on the bucket and hoe pins&bushings. All else seems fine.
That doesn't worry me. After surviving that many hours it isn't likely that any mechanical part will suddenly decide to fail, and I'm not likely to put another thousand hours on it.
So my expectation is that it will continue to work just as it does now for a long time.
Sort of a side thought is that few would buy a house, boat, or airplane without a complete professional survey, and the same thing is probably a good idea for buying used tractors as well.
rScotty
/ L39 TLB #28
I’m not hating on the Kubota TLBs. Truth be known I just traded my Deere for one. But if I had to pick one to run to 10,000 hours I’d want my Deere back. I’m not sure about the cost less part either. I paid money to trade for the Kubota. IMG_7525.JPG
/ L39 TLB #29
I’m not hating on the Kubota TLBs. Truth be known I just traded my Deere for one. But if I had to pick one to run to 10,000 hours I’d want my Deere back. I’m not sure about the cost less part either. I paid money to trade for the Kubota. View attachment 623258
Kubota M59......a dream machine....
....or maybe..... the M62 ????
/ L39 TLB #30
It’s a M59. I’d rather have one of those vs the m62.
/ L39 TLB #31
I have an L39 (460 hrs), M59 (270 hrs), 6415 Deere (1250 hrs). They all have their place but I'm still amazed at how much work the 39 & 59 will do for their size. For awhile, I thought of selling the L39 and replacing with a smaller, cheaper AG Kubota but I remembered what a pain it is to search for a clean, low-hour machine, bring all the maintenance up to date, sell the L39, and furthermore, there are so many things that a tractor smaller than a 39 won't be able to do. Even pushing snow, I wouldn't want the 6000 lb 39 to weight any less, and for sure, a FEL that won't lift at least 2k limits you to gardening type applications.
/ L39 TLB #32
Yup....You should definitely keep your L39,..... and sell your M59 to me!
/ L39 TLB #33
Buy one. You won't be sorry. Be sure and get the hydraulic thumb and aux's to the front for a grapple. It doubles their utility. I don't like the HST for ground-engaging implements but for everything else, amazing.
/ L39 TLB #34
I was just kinda pulling your chain a bit about selling either of them.
I am very happy to already have a 250 hour 2006 L48 with 3rd function, diverter, hydraulic thumb, and 3 remotes.
But....who wouldn't rather have an M59?
An M59 ain't gonna happen to me though, as I am just a bit too old to change horses.
/ L39 TLB #35
Your L48 will probably outlast my M59. Nice find!
66'' BUCKET WITH TEETH (A61567)
66'' BUCKET WITH...
2010 John Deere 7330 Premium (A64126)
2010 John Deere...
SHOP BUILT TRI-AXLE LOWBOY TRAILER (A63291)
SHOP BUILT...
2008 Ford F-550 4x4 Landscape Dump Truck with Lift Gate (A61568)
2008 Ford F-550...
2021 CATERPILLAR 730 OFF ROAD DUMP TRUCK (A62129)
2021 CATERPILLAR...
Kubota V3300-T-E3BG Turbo Diesel Engine - 3.3L - 84 HP - 2018 - Tier 4 Interim (A63689)
Kubota...
