l39 relief valve
   / l39 relief valve #1
jjk9178
can someone give me the info on a slight adjustment for the pressure relief valve (location) as now it is not lifting even the rated capicity.
   / l39 relief valve #2
The relief valve is adjusted with special washers that can be obtained through Kubota. You also need a pressure valve plumbed into the system to set the limits. If the machine is still under warranty it is best to let the dealer check the pressure setting and adjust if needed. If you were to set the relief pressure higher than factory specs there would be warranty issues when things started breaking in my opinion. .
MarkV
2009 PARKER 25 T/A GOOSENECK TRAILER (A52472)
2009 PARKER 25 T/A...
UNUSED HURRICANE F10 10' WROUGHT IRON SITE FENCE (A51248)
UNUSED HURRICANE...
UNUSED JCT HYD AUGER (A51248)
UNUSED JCT HYD...
2012 UNVERFERTH 10-INCH FRONT WHEEL SPACER FOR 10 BOLT HUB (A53472)
2012 UNVERFERTH...
UNUSED FUTURE FT-P45 HYD BREAKER HAMMER (A51248)
UNUSED FUTURE...
TMA (A49461)
TMA (A49461)
