l39 relief valve
   / l39 relief valve #1
jjk9178
can someone give me the info on a slight adjustment for the pressure relief valve (location) as now it is not lifting even the rated capicity.
   / l39 relief valve #2
The relief valve is adjusted with special washers that can be obtained through Kubota. You also need a pressure valve plumbed into the system to set the limits. If the machine is still under warranty it is best to let the dealer check the pressure setting and adjust if needed. If you were to set the relief pressure higher than factory specs there would be warranty issues when things started breaking in my opinion. .
MarkV
(5) PARTIALLY COMPLETED TRAILER RAMPS (A51247)
(5) PARTIALLY...
4"x8' Treated Post, 36 Piece Bundle (A52384)
4"x8' Treated...
2011 CATERPILLAR 140M2 MOTORGRADER (A51246)
2011 CATERPILLAR...
FRONTIER AH11G LOT IDENTIFIER 100 (A53084)
FRONTIER AH11G LOT...
2017 HITACHI ZX350LC EXCAVATOR (A53426)
2017 HITACHI...
2011 John Deere 5075M 75HP 4WD Loader Utility Tractor (A52377)
2011 John Deere...
