L39 Hyd return question
   / L39 Hyd return question #1
maineroads
I have a L39 that I would like to put a wood splitter on. I would like to run it off the backhoe pump (11gpm). The problem I have is what to do with the swing pump outlet. Can I run the swing pump to a t to the splitter return or should I include the swing pump in the feed to the splitter with a t, or neither? Thanks, Steve
   / L39 Hyd return question #2
Welcome to TBN:D
I think you will have to T into the return, just make sure the hose is sized adequately.
Thanks for the advice and the welcome! Good reading here. Steve
After speaking with the dealer and Kubota, they advise not to t the swing pump into the return of the other pump. Back pressure issues. looks like the rear backhoe outlets can only be used for the backhoe. there is no provision for returning the flow of the pump not used. (2 pump feed). Thoughts
   / L39 Hyd return question #5
When the backhoe is mounted, it goes into the same return correct? You have two pressure lines and one return?
Yup, for some reason Kubota and a local hydraulics manufacturer recommend not t-ing due to back pressure issues?
2015 Ford F-550 Godwin 184U Crew Cab Mason Dump Truck (A51692)
2015 Ford F-550...
2008 Ford F-450 4x4 Crew Cab CM Service Truck (A52377)
2008 Ford F-450...
20' Multi Door One Way Ship Container (A52384)
20' Multi Door One...
2005 Nissan Frontier 4x4 Pickup Truck, VIN # 1N6AD07W35C433334 (A51572)
2005 Nissan...
2019 CATERPILLAR 289D3 SKID STEER (A51246)
2019 CATERPILLAR...
2019 KENWORTH T680 SLEEPER (A52577)
2019 KENWORTH T680...
